I lock entities (i.e., billboards with labels and images) to the ground using sampleTerrain() (similar to the Everest sample). It almost works, except some of the entities float above the terrain whereas others "sink" into the terrain. When I zoom in/out, the entities sink/float more.
I recently read that setting HeightReference to Cesium.HeightReference.CLAMP_TO_GROUND" is now supported. However when I try to clamp the entities to the ground, I still have the same sink/float problems.
The following simplified sandcastle illustrates the problem (a "sunken" entity). Did I implement the clamp to ground functionality correctly? Should I still be calling sampleTerrain() (as I am) when using clamp to ground? Thanks!
var positions = [ Cesium.Cartographic.fromDegrees( -111.572177, 40.582083 ) ];
animation: false,
fullscreenButton: false,
geocoder: false,
homeButton: false,
sceneModePicker: false,
selectionIndicator: true,
timeline: false,
scene3DOnly: true,
baseLayerPicker : false,
terrainProvider : new Cesium.CesiumTerrainProvider({ url : ‘http://assets.agi.com/stk-terrain/world’ })
function addEntities() {
viewer.scene.globe.depthTestAgainstTerrain = true;
viewer.entities.suspendEvents();
var theEntity = viewer.entities.add({
position : Cesium.Ellipsoid.WGS84.cartographicToCartesian( positions[0]),
billboard :{
image : '../images/facility.gif',
verticalOrigin : Cesium.VerticalOrigin.BOTTOM
HeightReference : Cesium.HeightReference.CLAMP_TO_GROUND
viewer.entities.resumeEvents();
viewer.flyTo(
theEntity, {
offset : new Cesium.HeadingPitchRange( Cesium.Math.toRadians( 165 ), Cesium.Math.toRadians(-20), 1500
Cesium.when( Cesium.sampleTerrain( viewer.terrainProvider, 9, positions ), addEntities );
