Hi, I found a bug while solving one of the issues and I fixed the bug, but I have committed the code to the branch in which I was solving the issue. How do I commit that file which has the bug to a new branch?
Thanks in advance..
Thanks in advance..
There are two options.
Simply create a new branch off of your master branch and commit the fix there.
If (and only if) you fixed the bug in a commit by itself; you can use the git cherry-pick command, which takes a commit from one branch and applies it to another.
Usually 1 is easier to do and that’s what I would recommend.
Thanks a lot, I have committed the files to a new branch and have made a pull request..
