screenSpaceCameraController.maximumZoomDistance does not seem to work in 2D. When I go to 2d it seems to limit the camera height to around 40,000 km regardless of screen size. Worse yet, if I programatically zoom out farther, for example camera.flyHome() with some default rectangle, as soon as the user tries to zoom in or out it will snap back to that 40,000km distance
viewer.scene.screenSpaceCameraController.maximumZoomDistance = 60000000;
Cesium.Camera.DEFAULT_VIEW_RECTANGLE = Cesium.Rectangle.fromDegrees(-80,-90,100,90);
setInterval(()=>{
console.log(viewer.camera.positionCartographic.height);
},2000)
I am trying to control limits of zooming and panning in 2D. I would like to set the max zoom distance in 2D to be the width of the earth. Setting DEFAULT_VIEW_RECTANGLE works to zoom to map height but not width.
Cesium v1.61
Chrome Version 77.0.3865.90 (Official Build) (64-bit)
Windows 10 64-bit
