Measure North Bearing for a line
I am trying to calculate the clockwise angle from north pole to a line. I draw a line on the globe in the following way:
I create a line after clicking once at the start and then at the end point something like:
if(!entity) {
entity = viewer.entities.add({
polyline : {
positions : [firstPoint, cartesian],
width : 10.0,
material : new Cesium.PolylineArrowMaterialProperty(new
Cesium.Color(1.0, 0.0, 0.0, 1.0)),
depthFailMaterial : new Cesium.PolylineArrowMaterialProperty(new
Cesium.Color(1.0, 0.0, 0.0, 0.5)),
nonPickable: true,
} else {
entity.polyline.positions = [firstPoint,endPoint];
How can i now measure the north bearing for this line, or any line i draw on the globe like this?
You can calculate bearing between 2 points like this:
function calculateBearing(startPoint, endPoint) {
    var start = Cesium.Cartographic.fromCartesian(startPoint);
    var end = Cesium.Cartographic.fromCartesian(endPoint);
    var y = Math.sin(end.longitude - start.longitude) * Math.cos(end.latitude);
    var x = Math.cos(start.latitude) * Math.sin(end.latitude) -
        Math.sin(start.latitude) * Math.cos(end.latitude) *
        Math.cos(end.longitude - start.longitude);
    var bearing = Math.atan2(y, x);
    return Cesium.Math.toDegrees(bearing);
  • Regards
