I have a overlay I have built and have two billboards to show different locations. Is there a way to measure between the two? I have seen points done but not billboards.
HI @jeffpenn82, thanks for the question.
You should be able to do the same type of logic to measure between 2 billboards. You can get their positions using Billboard.position.
If you just want the distance between the two points you can use Cartesian3.distance(). If you want the distance on the actual ellipsoid you can use either EllipsoidGeodesic or EllipsoidRhumbLine which both have a surfaceDistance property
