The discussion here may be helpful: Performance differences due to distance. Specifically, if you have lines over a long distance, you can set the arcType to NONE to reduce the amount of computations needed if you don’t need CesiumJS to handle curving the line over the surface of the Earth for you.
omar
2
Related topics
| Topic | Replies | Views | Activity | |
| Drawing a Path dynamically (High Memory Uses) | 1 | 351 | August 21, 2014 | |
| Entities CPU and Memory Performance. | 2 | 342 | November 27, 2017 | |
| Issues with Polylines with large number of points | 2 | 232 | May 31, 2014 | |
| Maximum number of elements in positions of Polyline | 4 | 242 | August 5, 2014 | |
| Does Cesium.js Entity Polyline "compress" positions? | 4 | 92 | April 24, 2026 |
