Hi!
I'm trying to use the camera.moveForward method to zoom the map with enabledZoom set to false. It works perfectly in 3d, even though, when the map is set to 2D mode, it simply stops moving the camera after calling the method. You can check this behaviour in the camera tutorial in sandcastle http://cesiumjs.org/Cesium/Apps/Sandcastle/index.html?src=Camera%20Tutorial.html&label=Showcases , just change the map type to 2D and the w and s for zoom will simply stop working. Does anyone know if this is a bug or if i'm supposed to use a different method for zooming in 2d?
Greetings
