I’m trying to get the Cesium Camera to fly to a direction at the current Cesium Camera height behind an entity billboard(in this case a satellite in the sky) and adjust the camera heading, pitch and roll to have the camera looking at the entity directly behind looking down at a footprint entity at the ground. This position is not usually directly beneath the space entity and projected at an angle on the Earth from it. I don’t want to lookAt or get the camera locked on to the entity, just simply move to that pointing position. I feel like there should be an easy way to do this, but despite my best efforts I can’t seem to get it to work.
No code of getting it to work, however i would have 2 entities with Cesium.Cartesian3(0, 0, 2000)satellite and Cesium.Cartesian3(1.5, 1.5,0)ground entity
User requirement
Using Cesium 1.58.1, Windows 10, and Chrome
