hi am new to cesium i have a confusion to move the model on a dynamically drawn poly-line can u please give some suggestion
See this example: http://cesiumjs.org/Cesium/Apps/Sandcastle/index.html?src=Interpolation.html&label=Showcases
-Hannah
Thank you Hannah Pinkos…
Happy new year!!!
i follow the tutorial am done some modification as per my requirement but one thing when am remove clock change loop at the end of line the model was disappear may i know how to show the model at the end of path
Happy new year!!!
Happy new year!
Can you please explain your question a little more? I don’t quite understand what you’re asking.
Hannah
The model was moving on line in a loop mode but i want to stop the model at line end and show the model was stopped.
Since the model moving is linked to the clock time, you’ll need to define what happens to the model when it passes the last time in the availability. One option would be to extend the availability and add a another point to the SampledPositionProperty with the same position and a time way in the future.
-Hannah
Yeah i got it Hannah thank fro your support.
