multiple baseLayers
Is it possible to add multiple baseLayers like this one map selecion: https://cesiumjs.org/Cesium/Build/Apps/Sandcastle/?src=Imagery%20Layers%20Manipulation.html
Thanks
Yes, take a look at the Cesium Imagery Layer Tutorial.
Json load as base layer example? Please.
And for multiple baseLayers with list select…array of baseLayers?
Thanks
