is it possbile block the multiplier?
For example set X30 as superior limit?
Gianmaria
Gianmaria
You can set viewer.animation.viewModel.defaultTicks to represent the clock multipliers. Something like this may work for you:
viewer.animation.viewModel.defaultTicks = [0.001, 0.002, 0.005, 0.01, 0.02, 0.05, 0.1, 0.25, 0.5, 1.0, 2.0, 5.0, 10.0, 15.0, 30.0];
Hannah
Thanks for your answer.
Using your hint I discovered that the correct method is:
viewer.animation.viewModel.setShuttleRingTicks([0.001, 0.002, 0.005, 0.01, 0.02, 0.05, 0.1, 0.25, 0.5, 1.0, 2.0, 5.0, 10.0, 15.0, 30.0]);
as properly explained in the documentation.
Gianmaria
