Hi All,
I’m trying to specify a simple shader set for displaying buildings - loaded from gltf file - to get something like in Cesium buildings demos (gray buildings).
I have tried to used same shaders as in Cesium demo (extracted from a gltb file), but result is very different… and I see two possibilities : either I failed in adapting the shaders (normals in these gltb file seems encoded on two values), or my normals are wrong.
Here is the code of my shaders after adaptation :
precision highp float;
uniform vec4 u_ambient;
uniform vec4 u_diffuse;
uniform vec4 u_emission;
uniform vec4 u_specular;
uniform float u_shininess;
varying vec3 v_normal;
varying vec3 v_positionEC;
void main(void) {
vec3 normal = normalize(v_normal);
vec4 color = vec4(0., 0., 0., 0.);
float diffuseIntensity = 0.0;
float specularIntensity = 0.0;
vec4 diffuse = vec4(0., 0., 0., 1.);
vec4 emission;
vec4 ambient;
vec4 specular;
diffuse = u_diffuse;
ambient = diffuse * 0.5;
emission = u_emission;
specular = u_specular;
vec3 normalizedpositionToEyeEC = normalize(-v_positionEC);
diffuseIntensity = czm_getLambertDiffuse(czm_sunDirectionEC, normal);
specularIntensity = czm_getSpecular(czm_sunDirectionEC, normalizedpositionToEyeEC, normal, u_shininess) +
0.25 * czm_getSpecular(czm_moonDirectionEC, normalizedpositionToEyeEC, normal, u_shininess);
color.xyz += ambient.xyz;
color.xyz += diffuse.xyz * diffuseIntensity;
color.xyz += specular.xyz * specularIntensity;
color.xyz += emission.xyz;
color = vec4(color.rgb * diffuse.a, diffuse.a);
gl_FragColor = color;
void main(void) {
vec4 emission;
vec4 ambient;
vec4 specular;
Note that the GLTF file use the CESIUM_RTC extension.
I saved my model as OBJ and normals seem good (in MeshLAB) :
But display in cesium is…not what I expected :
I would like to check if normals are good in the GLTF file & after loadig in Cesium.
I’m wondering if it is possible to use Cesium.createTangentSpaceDebugPrimitive on a gltf model loaded with something like :
var model = scene.primitives.add(Cesium.Model.fromGltf({
url : 'http://xxxx'
Any help appreciated,
Fred.
