I am working on line of sight on tyhe new york 3D tile data. I want to project color over feature which are visible to human eye and color the building which is visble and give another color which are not visble to human eye
I have used 3dtileset data ,and tileload function to get an array of 3d tile and passing the content to another function where calculation is done for visibility. Here am not able to color the object building with matchin height or coordinates.
var tileset = viewer.scene.primitives.add(new Cesium.Cesium3DTileset({
url: ‘https://beta.cesium.com/api/assets/1461?access_token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJqdGkiOiJkYWJmM2MzNS02OWM5LTQ3OWItYjEyYS0xZmNlODM5ZDNkMTYiLCJpZCI6NDQsImFzc2V0cyI6WzE0NjFdLCJpYXQiOjE0OTkyNjQ3NDN9.vuR75SqPDKcggvUrG_vpx0Av02jdiAxnnB1fNf-9f7s’,
shadows: true,
terrainShadows: Cesium.ShadowMode.ENABLED,
/* classificationType : Cesium.ClassificationType.TERRAIN,*/
tilesLoaded : true
var tileset_data=;
tileset.tileLoad.addEventListener(function(tile) {
var content = tile.content;
//console.log(“maincontent===”);console.log(content);
//var l=0; console.log(“datacontent===”+content.getFeature(l).getProperty(‘latitude’));
for (var i = 0; i < content.featuresLength; i++) {
var feature = content.getFeature(i);
tileset_data[i]=;
tileset_data[i]['latitude']=content.getFeature(i).getProperty('latitude');
tileset_data[i]['longitude']=content.getFeature(i).getProperty('longitude');
tileset_data[i]['area']=content.getFeature(i).getProperty('area');
tileset_data[i]['height']=content.getFeature(i).getProperty('height');
tileset_data[i]['SOURCE_ID']=content.getFeature(i).getProperty('SOURCE_ID');
tileset_data[i]['name']=content.getFeature(i).getProperty('name');
console.log(tileset_data,content);
function LOS(tileset_data,content);
// again i tried changing color for height more than 50
for (var l = 0; l < content.featuresLength; l++) {
if(content.getFeature(l).getProperty >50){
content.getFeature(l).color=Cesium.Color.LIME;
}else{
content.getFeature(l).color = Cesium.Color.CORAL;
I am working on line of sight on tyhe new york 3D tile data. I want to project color over feature which are visible to human eye and color the building which is visble and give another color which are not visble to human eye.
1.44 cesuim, windows 10
