The label is split with the background, and the billboard is not clamped to ground.
see: https://imgur.com/a/4DN0Z
I need clamp to ground to work so that I can clamp things to the ground.
Cesium 1.38. OSX 10.12.6. Chrome 62.0.3202.38.
Tested on Safari 11.0 as well and it seems to work. May be an issue with Chrome on OS X?
