When you add first or second, labels are always under polylines. Example:
This is a known issue in Cesium documented here: https://github.com/CesiumGS/cesium/issues/4108
A workaround is to change the eyeOffset. Please see this sandcastle.
Yea, seems that eye offset -50 does the trick. It is strange that that doesn’t happen on 3d mode. muy bien, gracias.
Update, eye offset doesn’t work on rotatable map ![]()
I have added to the issue mentioned above to record this case: https://github.com/CesiumGS/cesium/issues/4108
