We’re using Cesium 1.3 until now, and I now tried to upgrade to 1.6
Now all picking code is broken, when drillPick() is called there is an exception:
Uncaught DeveloperError: id is required
IDs are required now for picking?
I did not find anything in the change log related to this.
I tried passing a custom id to my primitives, however it is not working…
I tried adding an id to a constructor both in a GeometryInstance and a Primitive, none seem to work!
Also I checked the constructor of the primitive, found no code there related to getting a id from arguments and storing it on the instance fields.
Also I looked at the sandcastle picking sample, found no custom IDs in the primitives creation code, why?
