**1. I added pointcloud ****and a kml polyline **data to the Cesium, if i set polyline clamping to the ground, you can see the result as the follow image
but if i change polyline clamping to groung to false, the result as the floow image
clampToGround: false;
clampToGround: true;
I want to diaplay powerline pointcloud data with a vector line
cesium-1.37
