Polygon Geometry
viewer.entities.add({
                    polygon: {
                        hierarchy: Cesium.Cartesian3.fromDegreesArray(`[${newStr}]`
                        material: Cesium.Color.RED,
It’s not work but when i change [${newStr}] to [105.49979221347314, 20.994954320132283, 105.49955269297402, 20.99498788234124, 105.4994677940948, 20.99493045303432, 105.49942320801233, 20.994716751005587, 105.49937204716026, 20.994504336884123, 105.49931435465778, 20.9942933859599] it work, actually [${newStr}] is geometry from geocode features
Remember that what you add is a JSON blob of configuration data, there’s no inherit parser for any internal variables you might think of. Not sure where your ${newStr} comes from, nor what’s in it? Nor what you’re trying to achieve as such?
Cheers,
Alex
`var resource = new Cesium.Resource({
            url: endpoint,
            queryParameters: {
                where: `UPPER(qh_tenda) LIKE UPPER('%${input}%')`,
                outFields: "*",
                returnGeometry: true,
                resultRecordCount: 10,
                f: "geojson",
        return resource.fetchJson().then(function (results) {
            return results.features.map(function (resultObject) {
                var bboxDegrees = resultObject.geometry.coordinates[0];
                var newStr = JSON.stringify(results.features[0].geometry.coordinates[0]).replaceAll("[", "").replaceAll("]", "");`
I’m trying to change geojson to string to put into
`viewer.entities.add({
                    polygon: {
                        hierarchy: {
                            positions: Cesium.Cartesian3.fromDegreesArray(`[${newStr}]`),
                        material: Cesium.Color.BLUE.withAlpha(0.5),
                        height: 0,
                        outline: true, // height is required for outline to display
i want to hightlight features
i’m want geometry results change to polygon
I’m sorry, but I’m having a hard time understanding what you’re after and doing. You got a GeoJSON, you pull out some coordinates, and then convert it to a string to inject into a JSON blob for entity creation?
A quick look at your code, I think you’ve got a few misconceptions about what is a string and what is JS. You pull out the coordinates into bboxDegrees, and as long as you’re happy they are WGS84 in degrees, all you have to do is;
    positions: Cesium.Cartesian3.fromDegreesArray( bboxDegrees )
But again, I might have misunderstood what you’re trying to do.
Cheers,
Alex
thank you so much for your hard support !!
but i have another question, viewer.geocoder.viewModel.destinationFound = function flyToDestination(viewModel, toado) { console.log("He", toado); // copy code zoom to console.log("He", toado[0][0]); viewer.camera.flyTo({ destination: Cesium.Cartesian3.fromDegrees( toado[0][0], toado[0][1], 50, ), }); var redPolygon = viewer.entities.add({ polygon: { hierarchy: Cesium.Cartesian3.fromDegreesArray(toado.flat()), material: Cesium.Color.ORANGE.withAlpha(0.5), }, }); };
i want to remove older polygon when i create a new polygon from toado, can you help me?
Well, it’s fairly easy in the sense that;
  1. Make a global variable for the highlight entity
  2. Check if it exists, and delete if it does
So, in psuedo-code;
   var highlight = null;
   function flyTo( coords ) {
      if ( highlight ) {
         viewer.entities.remove(highlight);
      highlight = viewer.entities.add({ ... });
Cheers,
Alex
thank you so much, let me try
