When I try to draw a polygon with a hole (the height of the polygon and the hole is different) I get bugs. When you look from above, everything seems perfect, but when I look from the side, some lines appear. Can you explain why this is happening?
thanks in advance!
You can see the details of the problem in the attached photos and an example with Sandcastle.
https://drive.google.com/drive/folders/1sncTnbf-j4BEveFzVdEfc7t6PchOogk0?usp=sharing
