Polygon material uses images, but the image is reversed.
cesium 1.47,Polygon material uses pictures, and pictures are normal,but in cesium1.48 cesium1.49 cesium1.50 Polygon material uses images, but the image is reversed
var addPolygon = viewer.entities.add({
polygon: {
hierarchy: polygonPositionsC,
height: 0.5,
perPositionHeight: true,
material: "./img/camera/44.png"
Chrome cesium 1.47 1.48 1.49 1.50
