Hello Lydia,
Yes, PolylinePipeline.scaleToSurface will raise the points of the polyline to the surface if it goes through the globe. It uses the EllipsoidGeodesic Patrick mentioned to find the subpositions.
I just realized that it returns a list of numbers instead of a list of Cartesian3s though. I re-worked the functions you need below so that it returns a list of Cartesian3s instead. Send your original positions to the scaleToSurfaceCartesian function, then use the returned list as your position input when you create a polyline.
function generateCartesianArcCartartesian(p1, p2, granularity, ellipsoid) {
var first = ellipsoid.scaleToGeodeticSurface(p1, scaleFirst);
var last = ellipsoid.scaleToGeodeticSurface(p2, scaleLast);
var separationAngle = Cartesian3.angleBetween(first, last);
var numPoints = Math.ceil(separationAngle/granularity);
var result = ;
var start = ellipsoid.cartesianToCartographic(first, carto1);
var end = ellipsoid.cartesianToCartographic(last, carto2);
ellipsoidGeodesic.setEndPoints(start, end);
var surfaceDistanceBetweenPoints = ellipsoidGeodesic.getSurfaceDistance() / (numPoints);
start.height = 0;
var cart = ellipsoid.cartographicToCartesian(start);
result.push(cart);
for (var i = 1; i < numPoints; i++) {
var carto = ellipsoidGeodesic.interpolateUsingSurfaceDistance(i * surfaceDistanceBetweenPoints, carto2);
cart = ellipsoid.cartographicToCartesian(carto);
result.push(cart);
return result;
funciton scaleToSurfaceCartesian(positions, granularity, ellipsoid) {
if (!defined(positions)) {
throw new DeveloperError(‘positions is required’);
granularity = defaultValue(granularity, CesiumMath.RADIANS_PER_DEGREE);
ellipsoid = defaultValue(ellipsoid, Ellipsoid.WGS84);
var length = positions.length;
var newPositions = ;
for (var i = 0; i < length - 1; i++) {
var p0 = positions[i];
var p1 = positions[i+1];
newPositions = newPositions.concat(generateCartesianArcCartartesian(p0, p1, granularity, ellipsoid));
var lastPoint = positions[length-1];
var carto = ellipsoid.cartesianToCartographic(lastPoint, carto1);
carto.height = 0;
var cart = ellipsoid.cartographicToCartesian(carto, cartesian);
newPositions.push(cart);
return newPositions;
Best Regards,
Hannah
