Polylines displayed beneath ground level when terrain provider is set
Adding a polyline to the map works when no terrain provider is defined. The shape is then buried beneath ground level when adding a terrain provider.
I would like to clamp the polyline to the ground level.
<!DOCTYPE html>
<html lang="en">
<head>
    <base href="https://cesiumjs.org/Cesium/Build/Apps/Sandcastle/gallery/">
    <title>Cesium Demo</title>
    <script type="text/javascript" src="../../../CesiumUnminified/Cesium.js"></script>
</head>
<body>
<style>
    @import url(../templates/bucket.css);
</style>
<div id="cesiumContainer" class="fullSize"></div>
<script id="cesium_sandcastle_script">
  function startup(Cesium) {
    'use strict';
      terrainProvider : Cesium.createWorldTerrain(),
    viewer.scene.globe.depthTestAgainstTerrain = true;
    var redLine = viewer.entities.add({
      name : 'Red line on the surface',
      polyline : {
        positions : Cesium.Cartesian3.fromDegreesArray(
            5.717999,45.180306,
            5.718722,45.180353,
            5.71879,45.180348,
            5.719401,45.180386,
            5.719543,45.180384,
            5.719679,45.180386,
            5.719834,45.180428,
            5.719941,45.180437,
            5.720066,45.180445,
            5.720916,45.180496,
            5.721048,45.180506,
            5.721155,45.180514,
            5.721429,45.180537,
            5.721944,45.18058,
            5.722014,45.180579,
            5.722192,45.180598,
            5.722411,45.180624,
            5.722595,45.180645,
            5.722701,45.180657,
            5.722982,45.180705,
            5.723298,45.180762,
            5.723468,45.180792,
            5.723755,45.180846,
            5.724686,45.181038,
            5.724789,45.181134,
            5.724958,45.181168,
            5.725183,45.181218,
            5.725661,45.181323,
            5.726021,45.181422,
            5.726587,45.18158,
            5.726844,45.181659,
            5.727266,45.181787,
            5.727294,45.181795,
            5.727506,45.181872,
            5.727608,45.181888,
            5.727703,45.18193,
            5.727843,45.18204,
            5.728544,45.182421,
            5.728573,45.182434,
            5.728693,45.182485,
            5.728925,45.182504,
            5.729653,45.182815,
            5.729995,45.182961,
            5.730373,45.183116,
            5.730456,45.183149,
            5.730543,45.183186,
            5.730957,45.183359,
            5.731313,45.183498,
            5.731375,45.183511,
            5.731433,45.18353,
            5.7315,45.183557,
            5.7315,45.183557,
            5.7315,45.183557,
            5.7315,45.183557,
            5.731536,45.183572,
            5.731595,45.183595,
            5.731641,45.183612,
            5.731683,45.183629,
            5.731755,45.183599,
            5.731814,45.183539,
            5.731962,45.183511,
            5.732586,45.183397,
            5.732641,45.183387,
            5.732728,45.183375,
            5.733406,45.183278,
            5.733509,45.183251,
            5.733584,45.183093,
            5.733642,45.183015,
            5.733656,45.182993,
            5.733785,45.182837,
            5.734136,45.182122,
            5.734183,45.182123,
            5.734297,45.182123,
            5.734393,45.182115,
            5.73443,45.182025,
            5.734468,45.181931,
            5.734519,45.18188,
            5.734516,45.18182,
            5.734678,45.181501,
            5.734708,45.181424,
            5.734771,45.181261,
            5.735001,45.180774,
            5.735019,45.180747,
            5.735106,45.180623,
            5.735189,45.180623,
            5.735521,45.180623,
            5.735552,45.180623,
            5.737679,45.180622,
            5.737816,45.180612,
            5.73785,45.180612,
            5.738844,45.180595,
            5.738844,45.180595,
            5.738844,45.180595,
            5.73886,45.180595,
            5.738919,45.180596,
            5.738982,45.180596,
            5.73905,45.180595,
            5.739103,45.180594,
            5.73985,45.180578,
            5.740471,45.180567,
            5.740806,45.18057,
            5.741017,45.180571,
            5.741223,45.180579,
            5.741471,45.180584,
            5.741588,45.180584,
            5.74186,45.18014,
            5.742037,45.179828,
            5.742059,45.179788,
            5.74213,45.17963,
            5.742152,45.179577,
            5.742304,45.179203,
            5.74239,45.17898,
            5.742418,45.178909,
            5.742461,45.178805,
            5.742467,45.178789,
            5.742532,45.178626,
            5.742573,45.178507,
            5.742582,45.178483,
            5.742617,45.178381,
            5.742641,45.178311,
            5.742671,45.178225,
            5.742693,45.178168,
            5.742707,45.178132,
            5.742726,45.178089,
            5.742653,45.178073,
            5.742694,45.17796,
            5.742778,45.177731,
            5.74284,45.177567
        width : 5,
        material : Cesium.Color.GREEN,
        depthFailMaterial : Cesium.Color.RED,
        followSurface : true,
  if (typeof Cesium !== "undefined") {
    startup(Cesium);
  } else if (typeof require === "function") {
    require(["Cesium"], startup);
</script>
</body>
</html>
I want to highlight a path from given coordinates. Said path should follow the ground elevations.
Normal material is set to Green, depthFailMaterial is set to Red so we can see the shape through the ground.
Cesium 1.45, Mac OS 10.13.4, Safari 11.1.
Polylines on terrain are coming soon! We’re working on them now, see our progress in Issue #2172. As a workaround in the meantime, you can use corridors.
Gabby
