Hello everybody,
Please run the following script in the Sandcastle (Cesium 1.26):
var options = {
camera : viewer.scene.camera,
canvas : viewer.scene.canvas
var kml = ‘…/…/SampleData/kml/facilities/facilities.kml’;
var ds;
Sandcastle.addToolbarMenu([{
text : ‘Load’,
onselect : function() {
//viewer.camera.flyHome(0);
ds = new Cesium.KmlDataSource(options);
ds.load(kml, options).then(function() {
console.log(‘loaded’ + ds.entities.values.length + ’ entities’);
text : ‘Add to viewer’,
viewer.dataSources.add(ds).then(function() {
console.log(‘added’);
text: ‘Remove from viewer’,
onselect: function() {
viewer.dataSources.remove(ds);
console.log(‘removed’);
], ‘toolbar’);
Sandcastle.reset = function() {
- Wait for “loaded” message in the console.
- Select “Add” in the toolbar menu. Wait for “added” message.
- Select “Remove” in the toolbar menu. Wait for “removed” message.
- Select “Add” again. The message “added” appears but the renderer crashes:
undefined
TypeError: Unable to set property ‘id’ of undefined or null reference
at BillboardVisualizer.prototype.update (http://cesiumjs.org/Cesium/Source/DataSources/BillboardVisualizer.js:145:17)
at DataSourceDisplay.prototype.update (http://cesiumjs.org/Cesium/Source/DataSources/DataSourceDisplay.js:262:17)
at Viewer.prototype._onTick (http://cesiumjs.org/Cesium/Source/Widgets/Viewer/Viewer.js:1478:9)
at Event.prototype.raiseEvent (http://cesiumjs.org/Cesium/Source/Core/Event.js:147:17)
at Clock.prototype.tick (http://cesiumjs.org/Cesium/Source/Core/Clock.js:309:9)
at CesiumWidget.prototype.render (http://cesiumjs.org/Cesium/Source/Widgets/CesiumWidget/CesiumWidget.js:682:13)
at render (http://cesiumjs.org/Cesium/Source/Widgets/CesiumWidget/CesiumWidget.js:72:25)
I’ve always thought that DataSource should be still usable after removing from viewer.dataSources. Is this wrong?
By the way, Cesium.KmlDataSource constructor needs one argument, the documentation must be incorrect.
Thanks, Boris.
