My project has one component that generates CZML, and passes it to another component which passes it to Cesium.processCzml(). The CZML has a series of images to be drawn on Polygons, with different Availability times. Cesium correctly loads this, and allows me to Play and Pause, etc., all as I expect.
The problem is that as I Play it, I see significant flashing (just the first time a section is played). The flashing first shows a white box (I assume, while the image is loading from the server), and then the image appears (I assume, once it's downloaded). Once I've played through a section of time, there is no flashing the next time through (which I assume is because the images are now cached).
Is there a way for me to pre-cache the images (or anything else), to avoid the flashing? I'm willing to make the user wait a bit initially, for the better experience.
P.S. I tried calling Cesium.loadImage() on each URL when loading the CZML, and saw them all load over the network - but I still saw the same flashing when playing them (the first time).
