Hi!
I’m visualizing 3D point clouds with Cesium and would like to visualize a height gradient (something like this: https://user-images.githubusercontent.com/3269617/33374948-e5173068-d510-11e7-9ef5-2df7b4833f74.png).
I am trying to accomplish this using 3D Tiles styles based on the POSITION_ABSOLUTE attribute.
When tinkering around with approximations for the point-to-ellipsoid distance problem, I noticed that there are visible artifacts in the gradient I’m getting.
This makes we wonder: What is the precision of the POSITION_ABSOLUTE attribute of a point? It seems like the precision used in styling is much lower than the precision used for placing the point. Or am I missing something else entirely?
See here for an example based on the “3D Tiles Point Cloud” sandcastle example.
In this example, I color points based on the fractional part of the z-axis component of the POSITION_ABSOLUTE attribute. What I would expect is a rather smooth greyscale gradient along some tilted axis (as the z-axis is not ‘up’). The visualization however shows basically two colors: Black and grey. This tells me that all points have a precision of not even one fractional digit?!
This is the same for the x-axis component. For some reason, the y-axis component seems to provide better results in the example.
If there is a better way to visualize a height gradient of the point cloud, I’m interested. However, I’d rather avoid pre-calculating (and storing!) that attribute for every point for all data sets that we have.
Sandcastle currently uses Cesium 1.62, I’m using Arch Linux and Firefox 69. I also reproduced the problem on a Windows 10 machine with Chrome.
