Problem about 3DTILES_bounding_volume_S2
I use 3DTILES_bounding_volume_S2, I like to start from level 5,not 0. how to config “tileset.json” or “subtree”? thanks.
Hi @wycgis
If I’m not mistaken, the API currently doesn’t allow user to start at an arbitrary subtree level. But if you want to modify tileset.json from the data source side, the way to do it is to assign the root with the implicit tileset extension and assign the subtree level 5 as the root subtree.
