Problem with Cesium-GeoserverTerrainProvider
Hello! I use GeoserverTerrainProvider version 1.0 and geoserver version 2.5.2.
To create elevation data I downloaded srtm_01_02.tif
and converted it: gdal_retile.py -s_srs EPSG:4326-v-r bilinear-levels 8-ps 64 64-co "TILED=YES" -co "COMPRESS=DEFLATE" -co ZLEVEL=4" -targetDir bmpyramid ./srtm_01_02.tif.
After I published in Geoserver, received http://photoshare.ru/photo11901698.html
and http://photoshare.ru/office/image.php?id=11901696
Wrote a program HelloWorld.html:
<!DOCTYPE html>
<html lang="en">
<head>
  <!-- Use correct character set. -->
  <meta charset="utf-8">
  <!-- Tell IE to use the latest, best version (or Chrome Frame if pre-IE11). -->
  <meta http-equiv="X-UA-Compatible" content="IE=Edge,chrome=1">
  <!-- Make the application on mobile take up the full browser screen and disable user scaling. -->
  <meta name="viewport" content="width=device-width, height=device-height, initial-scale=1, maximum-scale=1, minimum-scale=1, user-scalable=no">
  <title>Hello World!</title>
  <script src="../Build/Cesium/Cesium.js"></script>
  <script src="../Cesium-GeoserverTerrainProvider/GeoserverTerrainProvider.js"></script>
    <style>
      @import url(../Build/Cesium/Widgets/widgets.css);
      #cesiumContainer {
          position: absolute;
          top: 0;
          left: 0;
          height: 100%;
          width: 100%;
          margin: 0;
          overflow: hidden;
          padding: 0;
          font-family: sans-serif;
      html {
        height: 100%;
      body {
          padding: 0;
          margin: 0;
          overflow: hidden;
          height: 100%;
  </style>
</head>
<body>
<div id="cesiumContainer"></div>
  <script>
    var widget = new Cesium.Viewer('cesiumContainer');
    var scene = widget.scene;
    var camera = scene.camera;
    var primitives = scene.primitives;
    var terrainProvider = new Cesium.GeoserverTerrainProvider({
        url : "http://127.0.0.1:8080/geoserver/elevation/wms",
        layerName: "bmpyramid",
        heightmapWidth:64,
        styleName:"mySLD",
        waterMask:true
    scene.globe.terrainProvider = terrainProvider;
    var canvas = scene.canvas;
    var hand = new Cesium.ScreenSpaceEventHandler(canvas);
    // return altitude with double click in console.log!!
    hand.setInputAction(
            function (movement) {
                if(movement.position != null) {
                    var cartesian = scene.camera.pickEllipsoid(movement.position, ellipsoid);
                    if (cartesian) {
                        var cartographic = ellipsoid.cartesianToCartographic(cartesian);
                        cartographic.height=globe.getHeight(cartographic);
                        console.log("lat= "+(cartographic.latitude*180/Math.PI)+"°; long="+(cartographic.longitude*180/Math.PI)+"°; altitude="+cartographic.height+" meters")
            }, Cesium.ScreenSpaceEventType.LEFT_DOUBLE_CLICK);
  </script>
</body>
</html>
The program is not working http://photoshare.ru/photo11901697.html .
Please help me!
It seems you have a cross origin resource sharing (CORS) issue with your server. See http://en.wikipedia.org/wiki/Cross-origin_resource_sharing
You should see how to resolve it with your application server
Sorry, but I don't understand how to solve it. I use mozilla firefox. the Apache web server http 2.2.24
More information (and Apache instructions) are available at http://enable-cors.org/server_apache.html
Thank you! I was able to configure cors. I have configured a proxy on both apache and geoserver too.
