We've been running into some issues with Cesium labels. I've created an example that illustrates.
Basically all I'm doing is creating a set of labels by first adding the label collection, then creating labels and adding them one by one.
Then I remove some labels, and bad things happen. This is what I'm observing:
Remove three: Nothing bad happens until you try to clear, then you get errors.
Remove four or five: Everything is fine for a second, then Cesium dies.
Remove six: Everything is fine for a second, then the last remaining label
inexplicably disappears.
http://cesium.agi.com/Cesium/Apps/Sandcastle/?src=Billboards.html
Replace Javascript with this:
require([
'Source/Cesium', 'Widgets/Dojo/CesiumWidget',
'dojo/on', 'dojo/dom', 'dijit/form/Button'
], function(
Cesium, CesiumWidget,
on, dom, Button)
"use strict";
/* Create some global variables */
var pointArray;
var textArray;
var billboards;
var labels;
function addBillboards(scene, ellipsoid) {
/* Set up some variables to use */
pointArray = ;
textArray = ;
billboards = new Cesium.BillboardCollection();
labels = new Cesium.LabelCollection();
/* Add collections */
widget.scene.getPrimitives().add(billboards);
widget.scene.getPrimitives().add(labels);
/* Set up canvas */
var canvas = document.createElement('canvas');
canvas.width = 16;
canvas.height = 16;
var context2D = canvas.getContext('2d');
context2D.beginPath();
context2D.arc(8, 8, 8, 0, Cesium.Math.TWO_PI, true);
context2D.closePath();
context2D.fillStyle='rgb(255, 255, 255)';
context2D.fill();
var textureAtlas = widget.scene.getContext().createTextureAtlas({image : canvas});
billboards.setTextureAtlas(textureAtlas);
/* Add seven points */
for (var i = 0; i < 7; i++) {
/* Create label */
var text = new Cesium.Label({}, labels);
text = labels.add(text);
text.setPosition(ellipsoid.cartographicToCartesian(
Cesium.Cartographic.fromDegrees(-75.59777+Math.pow(-1, i)*i, 40.03883+i)));
text.setText("Point"+i);
textArray.push(text);
function removeThree(scene, ellipsoid) {
/* Remove points */
for (var i = 0; i < 3; i++) {
labels.remove(textArray[i]);
function removeFour(scene, ellipsoid) {
/* Remove points */
for (var i = 0; i < 4; i++) {
function removeFive(scene, ellipsoid) {
/* Remove points */
for (var i = 0; i < 5; i++) {
function removeSix(scene, ellipsoid) {
/* Remove points */
for (var i = 0; i < 6; i++) {
function createButtons(widget) {
var ellipsoid = widget.ellipsoid;
var scene = widget.scene;
var primitives = scene.getPrimitives();
new Button({
label: 'Add points',
onClick: function() {
primitives.removeAll();
addBillboards(scene, ellipsoid);
}).placeAt('toolbar');
new Button({
label: 'Remove Three',
removeThree(scene, ellipsoid);
new Button({
label: 'Remove Four',
removeFour(scene, ellipsoid);
new Button({
label: 'Remove Five',
removeFive(scene, ellipsoid);
new Button({
label: 'Remove Six',
removeSix(scene, ellipsoid);
new Button({
label: 'Clear',
var widget = new CesiumWidget();
widget.placeAt(dom.byId('cesiumContainer'));
widget.startup();
dom.byId('toolbar').innerHTML = '';
createButtons(widget);
