R: Re: [cesium-dev] navigation on on touch screen devices
Hi Guillaume,
I tried to use https://github.com/alberto-acevedo/cesium-navigation
but it does not work.
when I use ol3_cesium and I create the 3D map should I create a new Cesium.Viewer?
Now use only CesiumScene
var scene = ol3d.getCesiumScene ();
var = new terrainProvider Cesium.CesiumTerrainProvider ({
url: ‘//assets.agi.com/stk-terrain/world’,
requestWaterMask: false,
requestVertexNormals: false
scene.terrainProvider = terrainProvider;
ol3d.setEnabled (false);
in CesiumScene is possibie to add naigation controller?
Thank you so much.
Paolo
Hi Paolo,
Indeed OL3-Cesium is not using the Cesium Viewer or Widget so you may probably not be able to use the
cesium-navigation mixin directly.
With some adaptations, it might be possible to pass the OLCesium object to the CesiumNavigation constructor:
https://github.com/alberto-acevedo/cesium-navigation/blob/development/Source/CesiumNavigation.js
If you come up with something don’t hesitate to contribute it to OL3-Cesium.
Guillaume
