- I am trying to automate cesium viewer using Selenium. So far I have fetched the entity and fly to that entity. Now, I want to click on that entity so that the assigned event gets fired.
I am pretty new to cesium, help will be highly appreciated.
string script = @"viewer.render();
var dataSource = viewer.dataSources._dataSources[1];
if (dataSource)
for (var i = 0; i < dataSource.entities._entities._array.length; i++)
var name = dataSource.entities._entities._array[i].name.toString();
if (name.includes(""" + name + @"""))
console.log(i);
viewer.flyTo(dataSource.entities._entities._array[i], {duration: 5});
//viewer.scene.pick(dataSource.entities._entities._array[i].position);
- As listed above, to automate the testing process using Selenium.
