Read JulianDate from JSON
Cesium seems to like JulianDate everywhere so I want to store date values as JulianDate's directly in JSON, then read/write from disk instead of converting on the fly with Cesium.JulianDate.fromIso8601() since it's very slow.
When I read in the JSON JulianDate I can't seem to assign it in a way that's recognized by Cesium functions.
Old Code (Works, but too slow)
var start = Cesium.JulianDate.fromIso8601(result1[0][0]['UTC']);
New Code (Does not work)
var start = result1[0][0]['JD'];
Nick
Your code snippets don’t show the data you’re actually using. In any case, the fastest way to construct a JulianDate is to call the constructor, passing the dayNumber and secondsOfDay numbers in the TAI time standard, to avoid the UTC-TAI conversion.
https://cesiumjs.org/Cesium/Build/Documentation/JulianDate.html#JulianDate
Great, thanks. I'll store the 3 parts in JSON (separately) and reconstruct it that way.
