I’m doing a high elevation animation of an island and wanting to get a realistic ocean instead of the depth maps that currently show. Is there a way to customize only the ocean material?
Many thanks!
Many thanks!
Are you using Cesium World Terrain and its water mask? If so, then yes. You just need to copy MI_CesiumThreeOverlaysAndClippingAndWater from the Cesium for Unreal plugin into your own project, modify it as you see fit, and specify it as the Water Material on the Cesium3DTileset.
I am trying to do this the way @Kevin_Ring described but the parent material of the MI in question is M_CesiumBaseMaterial, which does not change the ocean rendering even though it is applied as the water material and I do not know how to modify it to make a more realistic ocean. Any more tips would be highly appreciated!
You didn’t answer my previous question: Are you using Cesium World Terrain? If not, the built-in water material won’t help. If you are, just make sure Cesium → Rendering → EnableWaterMask is enabled.
Hi, I am not the same person who started this thread but thanks I will make sure I am using it.
Understood, but that’s still the first question to anyone having trouble with water rendering.
