recommendation to provide Offline Terrain and SatImages
im currently looking into a Solution to provide terrain data and satelite images to my cesiumJS application.
Since I want to provide that services in my private network the ieda was to use geoserver but the results look currently like
that.
After some investigation I think the reason is, that Cesium needs the data as quantisied mesh format and geoserver can only provide that in the input format which was a hight map geotiff. It won’t interpolate the data for a smooth look so when the resolution is bad the result will also look bad.
Can someone recomend an alternative solution or know if I m doing some thing wrong?
Regards
Thomas
Hi @briddl1305,
Is this an application focused on a particular area? Terrain + satellite imagery for the whole globe is a huge dataset that could be hard to host locally unless you have a lot of resources.
There are a few routes you could take:
  1. Cesium ion self-hosted. This is a commercial (paid) solution that would just work, out of the box.
  2. Convert your terrain to 3D tiles, then follow the instructions of the Offline Guide. Since Drape Imagery on 3D Tiles Sandcastle (and make sure show/hide works) by ggetz · Pull Request #12642 · CesiumGS/cesium · GitHub was merged, you can now drape imagery on a 3D Tileset.
  3. Look for a height-map to quantized mesh converter. I found an interesting list of tools, but I am not familiar with most of them.
approx how much?
Hi @jjhembd,
focused area would be where I live (Germany) and not even. It is no to host the whole glob just to get it mobile for my private use. Geo server sounded like a nice open source solution for that.
Thanks for the suggestions.
@Aankit_K: Your Question is hard to answer, It depends on your data quallity, the data you want to include etc.. There is no good answer here like 1000 TB or something like that.
@jjhembd I am talking here about the cesium world terrain. I am sure you will have approx number regarding that.
Hi @Aankit_K ,
A colleague recently looked up those size estimates in this thread comment Offline dataset size estimations - #2 by janine
Hope that helps and please let us know if you have further questions.
Luke
