Hello everyone
I am trying to write a unit test.
And I use in my app in cesium.
And when I run the karma then he gives me the following error:
“ReferenceError: Can not find variable: Caesium”
this the karma.conf.js file
'use strict';
var path = require('path');
var conf = require('./gulp/conf');
var _ = require('lodash');
var wiredep = require('wiredep');
var pathSrcHtml = [
path.join(conf.paths.src, '/**/*.html')
function listFiles() {
var wiredepOptions = _.extend({}, conf.wiredep, {
dependencies: true,
devDependencies: true
var patterns = wiredep(wiredepOptions).js
.concat([
path.join(conf.paths.tmp, '/assets/cesium/Cesium/Cesium.js'),
path.join(conf.paths.tmp, '/serve/app/index.module.js')
.concat(pathSrcHtml);
var files = patterns.map(function(pattern) {
return {
pattern: pattern
files.unshift({
pattern: path.join(conf.paths.src, '/assets/**/*'),
included: false,
served: true,
watched: false
return files;
module.exports = function(config) {
var configuration = {
files: listFiles(),
singleRun: true,
autoWatch: false,
ngHtml2JsPreprocessor: {
stripPrefix: conf.paths.src + '/',
moduleName: 'colorPicker'
logLevel: 'WARN',
frameworks: ['phantomjs-shim', 'jasmine'],
browsers : ['PhantomJS'],
plugins : [
'karma-phantomjs-launcher',
'karma-phantomjs-shim',
'karma-coverage',
'karma-jasmine',
'karma-ng-html2js-preprocessor'
coverageReporter: {
type : 'html',
dir : 'coverage/'
reporters: ['progress'],
proxies: {
'/assets/': path.join('/base/', conf.paths.src, '/assets/')
// This is the default preprocessors configuration for a usage with Karma cli
// The coverage preprocessor is added in gulp/unit-test.js only for single tests
// It was not possible to do it there because karma doesn't let us now if we are
// running a single test or not
configuration.preprocessors = {};
pathSrcHtml.forEach(function(path) {
configuration.preprocessors[path] = ['ng-html2js'];
// This block is needed to execute Chrome on Travis
// If you ever plan to use Chrome and Travis, you can keep it
// If not, you can safely remove it
// https://github.com/karma-runner/karma/issues/1144#issuecomment-53633076
if(configuration.browsers[0] === 'Chrome' && process.env.TRAVIS) {
configuration.customLaunchers = {
'chrome-travis-ci': {
base: 'Chrome',
flags: ['--no-sandbox']
configuration.browsers = ['chrome-travis-ci'];
config.set(configuration);
thank you in advance for your cooperation
