Testing the following code with sandcastle demonstrates a problem when rendering a rectangle. Position Africa so that it is approximately in the middle of the render area. A white rectangular region should be rendered to the right-most side of the render area. This rectangle will visibly change size (shrink/expand) as the map is panned left and right.
Is this a bug, and if so, is there a workaround for it?
code follows…
var viewer = new Cesium.Viewer(‘cesiumContainer’,
sceneMode: Cesium.SceneMode.SCENE2D,
mapProjection: new Cesium.WebMercatorProjection()
viewer.entities.add(
rectangle: {
coordinates:
Cesium.Rectangle.fromDegrees(150.000000,0.000000, 180, 51)
Incidentally, I have tested the code above using 3D, and it works as expected.
I’ve been trying various things, and discovered that if I add an extrudedHeight propery of zero to the rectangle, then the “buggy culling” no longer occurs. However (and why is it there’s always a ‘however’
) adding the extrudedHeight causes the color issue that I recently reported here (https://community.cesium.com/t/colors-appearing-different-between-3d-and-2d/21634)
Perhaps this finding, if it hasn’t already been found by your team, will be helpful.
var viewer = new Cesium.Viewer('cesiumContainer',
rectangle: {
coordinates:
Cesium.Rectangle.fromDegrees(150.000000,0.000000, 180, 51),
extrudedHeight: 0
