Is there an easy way to calculate the transformation needed to reset the camera so it shows the current view in a North orientation? Similar to what clicking on ‘Reset to North’ button on google earth compass does.
Teme
Teme
Hello Teme,
I believe this should work:
var camera = viewer.camera;
camera.setView({
orientation: {
heading : 0
Hannah
Thanks Hannah! That seems to work.
Hey Hannah, it would be very cool if there was a way to rotate the camera’s orientation with a smooth animation (just like flyTo) instead of just setting it to it’s final value, any plans to implement this?
Actually, you can use similar options for flyTo:
camera.flyTo({
destination: camera.positionWC,
orientation: {
heading : 0,
pitch: camera.pitch,
roll: camera.roll
-Hannah
Works great! thanks
@hannah is there a better solution? Because when the camera is angled, it turns away from what you’re looking at. I need a rotation that preserves what’s in the center of the view.
Hello Hannah,
I’m trying to use flyTo() in 2d mode, try to change current view in a North orientation:
viewer.camera.flyTo({
destination: viewer.camera.positionWC,
duration: 0.5,
orientation: {
heading: 0,
pitch: viewer.camera.pitch,
roll: viewer.camera.roll,
but the camera behaves quite strangely, when using the same parameters, the camera changes its appearance, as for 3D, the function works fine there, I left an example in the sandcastle.
Ilya
