Please help me,
I'm using the 3d Model code sample in sandcastle but it not run correctly. I runs but don't search for 3d models.
In this line there is error(line 40): var hpr = new Cesium.HeadingPitchRoll(heading, pitch, roll);
Error description:
Uncaught TypeError: Cesium.HeadingPitchRoll is not a constructor
at createModel (3D%20Models2.html:40)
at Object.onselect (3D%20Models2.html:64)
at HTMLSelectElement.menu.onchange (Sandcastle-header.js:57)
I attached image from error message,
This code is code from 3d model in sandcastle:
<!DOCTYPE html>
<html lang="en">
<head>
<!-- Use correct character set. -->
<meta charset="utf-8">
<!-- Tell IE to use the latest, best version. -->
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<!-- Make the application on mobile take up the full browser screen and disable user scaling. -->
<meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1, minimum-scale=1, user-scalable=no">
<title>3d models</title>
<script type="text/javascript" src="../Sandcastle-header.js"></script>
<script src="../Build/Cesium/Cesium.js"></script>
<style>
@import url(../templates/bucket.css);
@import url(../Build/Cesium/Widgets/widgets.css);
html, body, #cesiumContainer {
width: 100%; height: 100%; margin: 0; padding: 0; overflow: hidden;
</style>
</head>
<body>
<div id="cesiumContainer" class="fullSize"></div>
<div id="loadingOverlay"><h1>Loading...</h1></div>
<div id="toolbar"></div>
<script>
infoBox : false,
selectionIndicator : false,
shadows : true
function createModel(url, height) {
viewer.entities.removeAll();
var position = Cesium.Cartesian3.fromDegrees(-123.0744619, 44.0503706, height);
var heading = Cesium.Math.toRadians(135);
var pitch = 0;
var roll = 0;
var orientation = Cesium.Transforms.headingPitchRollQuaternion(position, hpr);
position : position,
orientation : orientation,
model : {
uri : url,
minimumPixelSize : 128,
maximumScale : 20000
var options = [{
text : 'Aircraft',
onselect : function() {
createModel('../../SampleData/models/CesiumAir/Cesium_Air.glb', 5000.0);
text : 'Ground vehicle',
createModel('../../SampleData/models/CesiumGround/Cesium_Ground.glb', 0);
text : 'Hot Air Balloon',
createModel('../../SampleData/models/CesiumBalloon/CesiumBalloon.glb', 1000.0);
text : 'Milk truck',
createModel('../../SampleData/models/CesiumMilkTruck/CesiumMilkTruck-kmc.glb', 0);
text : 'Skinned character',
createModel('../../SampleData/models/CesiumMan/Cesium_Man.glb', 0);
Sandcastle.addToolbarMenu(options);
</script>
</body>
</html>
