Hey there. I have found that the STK-Terrain returns "undefined" for height (and writes a JS error to the console for the 404 from sampleTerrain) for certain coordinates that are valid. I have code below that shows the problem. As it is below, it will show undefined for height in the console and show a JS error. If you change the last line to tile depth of 9 instead of 11, it works properly.
//if you don't change the default Terrain Provider to the STK-Terrain below ([1]), then it will not happen, but you always get 0 for height because the default terrain has no heights
var terrainProviders = Cesium.createDefaultTerrainProviderViewModels();
var viewer = new Cesium.Viewer('cesiumContainer',{
terrainProviderViewModels:terrainProviders,
selectedTerrainProviderViewModel: terrainProviders[1],});
var terrainSamplePositions;
terrainSamplePositions = ;
var longitude = -2.1945539525212125;
var latitude = 0.8642748429733929;
var longitudeBad = -3.0145815911295206;
var latitudeBad = 1.024137168972982;
var position = new Cesium.Cartographic(longitude, latitude);
var positionBad = new Cesium.Cartographic(longitudeBad, latitudeBad);
terrainSamplePositions.push(position);
terrainSamplePositions.push(positionBad);
function sampleTerrainSuccess(updated) {
var ellipsoid = Cesium.Ellipsoid.WGS84;
var height = null;
viewer.entities.suspendEvents();
viewer.entities.removeAll();
for (var i = 0; i < updated.length; ++i) {
var position = updated[i];
var cartoPos = new Cesium.Cartographic(position.longitude, position.latitude);
console.warn('height = ' + position.height);
viewer.entities.add({
position : ellipsoid.cartographicToCartesian(position),
billboard : {
verticalOrigin : Cesium.VerticalOrigin.BOTTOM,
image : '../images/facility.gif'
viewer.entities.resumeEvents();
//Cesium.when(Cesium.sampleTerrain(viewer.terrainProvider, 9, terrainSamplePositions), sampleTerrainSuccess);
Cesium.when(Cesium.sampleTerrain(viewer.terrainProvider, 11, terrainSamplePositions), sampleTerrainSuccess);
