I'm using the sandcastle transform editor code, auto generate from the SDK documentations. (See this link for informations : https://groups.google.com/forum/?hl=en#!topic/cesium-dev/LexAuOtuX74
I have one method to add and one to remove the transform editor from my tileset. See code below.
My problem is the following :
1- I want to add the transform editor feature.
2- I want to remove the transform editor.
3- I want to re-add the transform editor
-> At this 3rd step, my matrix is completely broken. See my matrices below.
Matrix at the 1st step, (the good one).
0: -0.03951865649472124
1: 0.999218832783316
2: 0
3: 0
4: -0.7521127170183508
5: -0.02974572049084378
6: 0.6583628581654306
7: 0
8: 0.6578485666839492
9: 0.026017615640722525
10: 0.7527007021308304
11: 0
12: 4203770.257306522
13: 166368.59177953008
14: 4777829.734155258
15: 1
Matrix at the 3rd step, (the broken one).
0: 0
1: 1
2: 0
3: 0
4: 0
5: 0
6: 1
7: 0
8: 1
9: 0
10: 0
11: 0
12: 6378137
13: 0
14: 0
15: 1
I've tried things but nothing works.
- Copy the matrix from the 1st step to the 3rd step.
- Do my treatment out of my readyPromise
- Set the transform editor to "null" and not use the destroy method.
- Use the method desactivate instead of destroy.
Do you have any ideas?
Thanks.
Method to add the transform editor to my tileset.
this.transformEditor = new Cesium.TransformEditor({
container: this.viewer.container,
scene: this.viewer.scene,
transform: tileset.modelMatrix,
boundingSphere: tileset.boundingSphere
this.transformEditor.viewModel.activate();
Method to remove the transform editor to my tileset.
this.transformEditor.destroy();
Following my entire code.
toggleTransformEditor(tileset) {
tileset.readyPromise.then(() => {
const rootTransform = tileset.root.transform;
const modelMatrix = tileset.modelMatrix;
// Transfer root transform to the model matrix
Cesium.Matrix4.clone(rootTransform, modelMatrix);
Cesium.Matrix4.clone(Cesium.Matrix4.IDENTITY, rootTransform);
//Définition du widget transformEditor
//Enable widget.
//Circle widget position
// this.initialPosition =
Cesium.Cartesian3.clone(this.transformEditor.viewModel.position);
// this.initialHeadingPitchRoll =
Cesium.HeadingPitchRoll.clone(this.transformEditor.viewModel.headingPitchRoll);
// this.initialScale = Cesium.Cartesian3.clone(this.transformEditor.viewModel.scale);
destroyTransformEditor(){
if(this.transformEditor){
// this.transformEditor = null;
The context is simple, we want to have the possibility to add and remove the transform editor with a toggle button.
Cesium 1.57
Version 75.0.3770.100 (64 bits)
