serving terrain tiles off of S3
**Hi all, I’ve created a set of terrain tiles in Cesium Terrain Builder that I’d like to use as a CesiumTerrainProvider. It works when I tested with a local server. **
My question: is it possible to just upload those tiles to an S3 bucket and point Cesium at that, or do I need to actually use a server? If the former, are there any specific settings I need to use to make it work?
You can set up your s3 bucket as a static webserver. That should do the trick.
https://docs.aws.amazon.com/AmazonS3/latest/dev/HowDoIWebsiteConfiguration.html
Thanks. Maybe a dumb question, but which options should I be setting? I don’t see one that actually reads static webserver – is that different from the default?
Not a dumb question at all. I actually jumped the gun on answering the question. Setting the bucket as a webserver isn't necessary, sorry to lead you astray. You'll need to make your tiles public, and I believe you will need to add a CORS policy.
https://docs.aws.amazon.com/AmazonS3/latest/user-guide/add-cors-configuration.html
On the CORS configuration you can add the following:
<CORSConfiguration>
<CORSRule>
   <AllowedOrigin>*</AllowedOrigin>
   <AllowedMethod>GET</AllowedMethod>
</CORSRule>
</CORSConfiguration>
