I would like to show a non textured esri scene layer (Cesium.I3SDataProvider). It is showing correctly in ArcGIS web scene viewer but not in Cesium Viewer.
Is there any settings to apply to cesium viewer to show it correctly ?
Thanks.
Hi there,
Do you have a code example which can replicate the issue you’re seeing?
Thanks.
It looks like the normals are not provided as part of the scene layer. Do you know if this is expected?
If normals are not available, it’s still possible to apply post processing effects such as ambient occlusion which would approximate the shading on the left.
