I’m drawing paths using Cesium, but when the path comes across the 3d model I put, it disappears like this:
Is there any solutions to show the path inside the model?
Hello @xyflii,
my idea - if you use ’ PolylineGraphics may be options clampToGround & ‘zIndex’ can help you. Also very good - if you add Sandcastle sample link - for real look & test solution
Thank you for your help, but I’m using the pathgraphics because I want to track the route and it seems does not has the property of clamptoToGround , here is the code
let entity = this.viewer.entities.add({
availability: new Cesium.TimeIntervalCollection([
new Cesium.TimeInterval({
start: _start,
stop: _stop
parent:this.historyCache,
path: {
resolution: 1024,
trailTime: 8888888,
leadTime: 0,
material: Cesium.Color.YELLOW,
show: true,
width: 3,
position: property,
orientation: new Cesium.VelocityOrientationProperty(property),
