I noticed an issue with small polygons clipping.
In the bellow sandcastle example a series of small vertically oriented rectangular polygons, increasing in height, should be rendered, but the shorter rectangles clip to triangles, If I try and create two triangles to mimic the rectangle, the same results occur.
var scene = viewer.scene;
var instances = ,
dLong = -0.00001,
dLat = 0.00000001 ,
longitude =-122.95287197,
latitude = 49.16011209,
polyLength = 10,
startElevation = 5,
elevationFrom_m = 5,
elevationTo_m,
deltaElevation = 0,
i = 1,
polyPositions = ,
primitives;
primitives = scene.primitives;
var polys, poly;
for ( i = 1; i <= 20; i++) {
deltaElevation = 0.05 * i;
elevationTo_m = elevationFrom_m + deltaElevation;
polyPositions = [
Cesium.Cartesian3.fromDegrees(longitude, latitude, elevationFrom_m),
Cesium.Cartesian3.fromDegrees(longitude + polyLength * dLong, latitude + polyLength * dLat, elevationFrom_m),
Cesium.Cartesian3.fromDegrees(longitude + polyLength * dLong, latitude + polyLength * dLat, elevationTo_m),
Cesium.Cartesian3.fromDegrees(longitude, latitude, elevationTo_m),
Cesium.Cartesian3.fromDegrees(longitude, latitude, elevationFrom_m)];
instances.push( new Cesium.GeometryInstance({
geometry: new Cesium.PolygonGeometry.fromPositions({
positions: polyPositions,
perPositionHeight: true,
vertexFormat: Cesium.PerInstanceColorAppearance.VERTEX_FORMAT
attributes: {
color: Cesium.ColorGeometryInstanceAttribute.fromColor(Cesium.Color.fromRandom({alpha : 1}))
elevationFrom_m = elevationTo_m;
scene.primitives.add( new Cesium.Primitive({
geometryInstances: instances,
appearance: new Cesium.PerInstanceColorAppearance({ flat: true }),
show: true
var center = Cesium.Cartesian3.fromDegrees(longitude, latitude , startElevation),
heading = Cesium.Math.toRadians(0),
pitch = Cesium.Math.toRadians(-20.0),
range = 40.0;
viewer.camera.lookAt(center, new Cesium.HeadingPitchRange(heading, pitch, range));
