Hi,All
I display a very small wall, but if there are many points of the wall the texture will be distorted.
Please see the example of Sandcastle and attached image.
The right wall with 200 points has distorted texture.
If reduce the number of points to about 10 like the left wall, the distortion can be suppressed.
Can not you make sure that the texture does not distort even when there are many points?
Cesium : 1.45
OS : Windows 7 Professional
Browser : Chrome 66.0.3359.181 (Official Build) (64 bit)
Kobayashi
