Hello Support,
I can see Cesium library can support web based support using Java script .
Is there any way to develop as a stand alone application?
Is it support in Linux also? How to download and start cesium library on Linux?
Hello Support,
This blog post may be helpful for you: http://cesiumjs.org/2016/04/04/An-Introduction-to-Cesium-Desktop-Apps-with-Electron/
-Hannah
Hello Hannah Pinkos,
The link what you given really helpful to me. I have followed all the instructions. But I struck in creating package.
I have installed Node.js and done all the commands . I got folder structure like this,
YourFolderName/
├── index.html
├── main.js
├── node_modules/
├── cesium/
├── electron-packager/
└── electron-prebuilt/
└── package.json
I am failing at this command.
./node_modules/.bin/electron-packager . myfirstapp --platform=win32 --arch=x64.
I am getting the following error :
Unable to determine application name or Electron version. Please specify an appl
ication name and Electron version.
For more infomation, please see
https://github.com/electron-userland/electron-packager/blob/master/docs/api.md#n
ame or
https://github.com/electron-userland/electron-packager/blob/master/docs/api.md#v
ersion
and also I have attached my package.json file also.
package.json (289 Bytes)
The problem is resolved… Sorry I forgot to run command “npm install electron-prebuilt --save-dev”
Now it is working fine. Thank you very much once again.
Great! Glad to hear you were able to figure it out =)
What kind of application are you working on?
I got success in windows. Made stand alone application nicely.
But in linux, I have followed the same procedure as it is.
But final command failing `"./node_modules/.bin/electron ."
I am getting following error while running above command.
``/opt/testapp/node_modules/electron-prebuilt/dist/electron: /usr/lib/libstdc++.so.6: version
CXXABI_1.3.5’ not found (required by /opt/testapp``/node_modules/electron-prebuilt/dist/electron) /opt/
testapp/node_modules/electron-prebuilt/dist/electron: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.14' not found (required by /opt/``````testapp
/opt/testapp``/node_modules/electron-prebuilt/dist/electron: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.15' not found (required by /opt/
testapp/node_modules/electron-prebuilt/dist/electron) /opt/``````testapp
/node_modules/electron-prebuilt/dist/electron: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.15’ not found (required by /opt/testapp
/node_modules/electron-prebuilt/dist/libnode.so)
Give me solution for this pls.
``On Friday, 21 October 2016 18:47:16 UTC+5:30, Hannah Pinkos wrote:
