When exporting a CZML file from STK where does the CZML converter get the radius value from for displaying sensors. I would expect it to come from the 3D space projection distance but that does not seem to be the case.
Thanks
Tim
Thanks
Tim
Sensor support in the converter is pretty incomplete. I just looked at the code and it was only using the range constraint (and only if it was enabled). Since it was only a couple of lines of code, I added support for a constant space projection value for you. Go through your normal AGI channels to request the latest copy of the converter.
