Storing and Retrieving Coordinates from CZML
I have a CZML file that define polylines. The coordinates for the polylines look like this…
polyline: {
positions: {
cartographicDegrees: [-1.87, -3.02, 0, -4.43, 1.28, 0]
material: {
solidColor: {
color: {
rgba: [255, 0, 0, 255]
width: 2,
clampToGround: true
I need to grab those coordinates to display them elsewhere on my GUI…
I sort out my polylines into an array and pick them up like this…
var pos = mylines[0].polyline.positions;
then I have two helper functions to convert the from cartesian coordinates and then place them in another array.
$.each( pos._value, function( key, value ) {
c3 = Cesium.Ellipsoid.WGS84.cartesianToCartographic(value)
c2 = parseCartographic(c3);
console.log("c2: " + c2);
cart.push(c2);
function parseCartographic(str) {
var res = str.toString().split(",");
var ret = “[” +res[0].replace("(","") + “,” + res[1].replace("(","") + “]”;
return ret ;
The cart variable comes out looking like this
**"cart: [[-0.030368728984701332, -0.05270894341022874],[0.01710422666954443, 0.03036872898470134]]"**
Why are the coordinates all jacked up?
see above
I want to draw a line based on this first line I get.
1.47, Windows10, latest Firefox.
Any help you can provide would be appreciated. Thanks,
Jody
The values returned by cartesianToCartographic() are in radians not degrees. Here’s what I did.
var czml = [{
“id” : “document”,
“name” : “CZML Geometries: Polyline”,
“version” : “1.0”
“id” : “redLine”,
“name” : “Red line clamped to terain”,
“polyline” : {
“positions” : {
“cartographicDegrees” : [
-75, 35, 0,
-125, 35, 0
“material” : {
“solidColor” : {
“color” : {
“rgba” : [255, 0, 0, 255]
“width” : 5,
“clampToGround” : true
var dataSourcePromise = Cesium.CzmlDataSource.load(czml);
dataSourcePromise.then(function(dataSource) {
viewer.zoomTo(dataSource);
for (var i = 0; i < entities.length; i++) {
var entity = entities[i];
var xyzArray = entity.polyline.positions.valueOf();
var llhArray = Cesium.Ellipsoid.WGS84.cartesianArrayToCartographicArray(xyzArray);
for (var j = 0; j < llhArray.length; j++) {
var llh = llhArray[j];
console.log(’(’ + llh.longitude * Cesium.Math.DEGREES_PER_RADIAN + ', ’ + llh.latitude * Cesium.Math.DEGREES_PER_RADIAN + ', ’ + llh.height + ‘)’);
Hope that helps.
Scott
Awesome. Thanks!!
