Terrain Elevation with ArcGIS Tiled Elevation Terrain
Unable to retrieve terrain height at a position using sampleTerrain. May be unsupported? Looking for a work around.
Paste into sandcastle
var terrainProvider = new Cesium.ArcGISTiledElevationTerrainProvider({
    url: ‘https://elevation3d.arcgis.com/arcgis/rest/services/WorldElevation3D/Terrain3D/ImageServer’
terrainProvider.readyPromise.then(function(isReady){
    console.log('Ready:'+isReady);
    viewer.terrainProvider = terrainProvider;
    var samplePos = [
      Cesium.Cartographic.fromDegrees(-77.134487059577509, 38.6777220281884)
    var promise = Cesium.sampleTerrain(viewer.terrainProvider, 15, samplePos);
    promise.then(function(promise){
        console.log('Latitude:' + Cesium.Math.toDegrees(samplePos[0].latitude));
        console.log('Longitude:' + Cesium.Math.toDegrees(samplePos[0].longitude));
        console.log('Height:' + samplePos[0].height);
Need to gather terrain heights at specific locations. Workarounds are acceptable
1.59
Sandcastle ArcGIS Tiled Elevation Terrain Example
I believe this is a bug - I posted some of my debugging notes here and pinged Tom Fili who might have a better idea where the issue is:
https://github.com/AnalyticalGraphicsInc/cesium/issues/8007
