I add satellite orbit from a czml file, and add cylinder under each satellite using the entity’s position CallbackProperty. But when I add more than one satellite, the program only render the last satellite’s cylinder in czml file, please help…
var dataSource = new Cesium.CzmlDataSource();
dataSource.process(‘./SampleData/satellite1.czml’).then(function() {
console.log(dataSource.entities.values.length);
var saEntity;
var nowPos = ;
for(var i=0;i<dataSource.entities.values.length;i++){
saEntity = dataSource.entities.values[i];
var isConstant = false;
var tmp = i;
viewer.entities.add({
position : new Cesium.CallbackProperty(function(time) {
nowPos[i] = Cesium.Ellipsoid.WGS84.cartesianToCartographic(saEntity.position.getValue(time));
console.log(tmp + “:” + time);
//if(i==0){ console.log(tmp + “:”+ time + “pos:” + nowPos[i]); }
return Cesium.Cartesian3.fromDegrees(Cesium.Math.toDegrees(nowPos[i].longitude),Cesium.Math.toDegrees(nowPos[i].latitude),0,Cesium.Ellipsoid.WGS84);
}, isConstant),
cylinder: {
length: new Cesium.CallbackProperty(function(time) {
return nowPos[i].height;
}, isConstant),
topRadius: 0.0,
bottomRadius: 300000.0,
material: Cesium.Color.RED.withAlpha(0.2),
cesium 1.51 ,chrome 70
