The fragment shader within appearance is unable to properly receive the uniform variable
I am currently using Cesium.Primitive and passing uniform data through fs and vs in appearance , finding that fs and vs cannot receive this uniform data, but ms can.
I wish to pass a float type value of ‘u_time’ as a uniform. However, when ‘u_time’ is utilized in ‘fragment shader’, an error occurs. Could you identify any mistakes in this transfer method?
My code and error are shown in the picture.
let material = new Cesium.Material({
    fabric: {
        type: 'Flow',
        uniforms: {
            image: '../image/blank.jpg',
            time: 0.0,
            u_time: 0.0,
        source: `
        czm_material czm_getMaterial(czm_materialInput materialInput) {
                czm_material material = czm_getDefaultMaterial(materialInput);
                material.diffuse = texture2D(image, newCoords).rgb;
                return material;
let fs = getFS();
function getFS() {
    source = `
    uniform float u_time;
    void main() {
        czm_materialInput materialInput;
        vec2 uv = gl_FragCoord.xy;
        uv.y += u_time;
    return source;
viewer.scene.primitives.add(new Cesium.Primitive({
    geometryInstances: coneInstance,
    appearance: new Cesium.Appearance({
        material: material,
        renderState: {
            blending: Cesium.BlendingState.ALPHA_BLEND,
            depthTest: {
                enabled: true
            cull: {
                enabled: true,
                face: Cesium.CullFace.BACK
            depthMask: true,
        fragmentShaderSource: fs,
        vertexShaderSource : vs,
微信图片_20230830160124
Hi there,
You’re trying to offset a vertex base on the value of u_time correct?
I’m not sure this way of offsetting vertices based on materials is the intended use case of the material system. I think the best way to do this would be to specify a BumpMap and create a texture from the u_time value.
Thank you for your advise, but I’ve used a data structure BumpMap to pass a two-dimensional array named u_time to the Material Shader (MS) before .
// adding bumpMapTexture
let bumpMapTexture = new Cesium.Texture({
    context: viewer.scene.context,
    pixelFormat: Cesium.PixelFormat.RG,
    pixelDatatype: Cesium.PixelDatatype.FLOAT,
    flipY: false,
    source: {
        arrayBufferView: u_time,
        width: 2,
        height: 2,
    fabric: {
        type: 'Flow',
        uniforms: {
            time: 0.0,
            u_time: 0.0,
			bumpMapTexture: bumpMapTexture,
        source: `
				vec2 timeRG = texture2D(bumpMapTexture, materialInput.st).rg; // adding bumpMapTexture
				newCoords = materialInput.st + timeRG * time;
                return material;
let fs = getFS();
function getFS() {
    source = `
    void main() {
        uv.y += u_time;
    return source;
        material: material,
        renderState: {
            depthTest: {
                enabled: true
            cull: {
                enabled: true,
            depthMask: true,
However, I found that the value is not being passed correctly. When I retrieve this value in the MS and add it to the coordinates, the result is not as expected. Do you know what could be the potential reasons?
It may help to know the final effect you’re looking to achieve.
If you’re looking to create a “flow” affect with the bumpMap (I’m just assuming this from your material name), I would recommend doing something like this sandcastle example.
